| Message |
While I had the engine out replacing my turbos, I took the opportunity to replace the knock sensor as well. Of course the connector was wasted, so I crimped on a mini female spade, stuck it on the terminal and potted it. Engine in and running, and I still have code 34. I tried the resistor trick and still no love. Will an out of spec resistance throw the code as well? I have read that the sensor normally has ~6M Ohm resistance ad I am wondering how I am throwing the code. I am going to see if I can borrow a buddy's o-scope tonight and look at the signal. I am also going to try putting the resistor in the engine harness side without the sensor connected to remove that variable. Any other ideas? (I did read the FAQ)
-Dan "Capitalization is the difference between helping your Uncle Jack off a horse, and helping your uncle jack off a horse." "'she' also likes to swap since I think I am going to need to give her to woody again." - Dvlhntr "full alphabetic boost mode" - ChristopherTheOne "Two oil eating, angry, spinning triangles of death." - turtleboy on rotary engines "You're the Skrillex of Z32s." BradX (UF) |
